Matt_martians
Alright so I'm finishing up my restoration. I'm going to pressure test my rotary valve case, but I'm pretty sure it's bad, so I'd need to remove the crank. I was wondering if anyone knows where to get good circlips from, and how to remove the piston pin without the piston pin tool. I am reusing my pistons, as they both at 150psi.
I was also wondering if anyone has hooked up an oil pressure guage to their oil pump, and how they did it. I don't like not knowing if I'm getting oil pressure, and there's no beeper for oil pressure, just for coolant temp. I want to fix that. I'm testing the pump while I'm doing this bottom end fix, but I want something that I can occasionally check in the future.
Also paint--- I currently have my engine out, and want to paint it. I will probably use spaypaint, and I want some reccomendations of paint type. I want to paint my engine red. If decent paint for this can only be found in paint cans, I can buy a paint gun. So rattle can and paint bucket reccomendations are welcome.
