oil outlet fitting
1994 seadoo sp. I broke off one of the oil outlet fittings, I was able to get the broken off piece out of the block but I need to re tap the hole. Does anyone know what size tap I will need to do this.
Thanks, Jerry
That's interesting. So anyway, the replacement fitting should have the threads you're looking for, might even be metric, I'd probably contact SBC engine builders b/c no doubt they have the nipple you need and probably can tell you the size.
Or take the piece you extracted to a local h/w and match it up assuming it's not too badly damaged.
NOTE: This is just for reference, not your style cases
Is it item #17? If so my above post should net you the correct info.
