Dadasaurus
Hi all,
I was hoping for suggestions for this problem. I have noticed that I have oil leaking out from where the oil level sensor plugs into the oil tank. The sensor itself is very loose. If I pull it out and put it back in, it is tight when I first put it in, but once I push it fully in place it's very loose. It's like over the years the top part of the plug has worn down.
I tried using a couple zip ties around the tank to hold the sensor down tight, but that only helped a little. The shape of the tank does not let the zip tie tighten very well.
I searched the forum and only found a couple mentions of this problem and saw where someone else also tried the zip ties, but did not see much else.
I was wondering if I cleaned the area well if I might be able to use some silicone (or other sealant) to run a bead around the sensor to keep it from leaking, but wasn't sure if there was any reason why I shouldn't do this, or if it just wouldn't adhere properly even after cleaning.
I would appreciate any suggestions, thanks!
