mattbraafhart
I noticed my 98 Sportster rotax 720's was leaking more oil than usual out the drain plug, after further investigation, the starboard engine has a large pool of oil on the rear engine mount which is dripping into the hull and out the drain eventually. I've also noticed that I haven't used as much oil this year as I typically do. Two questions then, how do I know the injection system is working properly? Is this a leaky hose or something worse? What should I check?
Thank you!
Thank you!
