WaTeRMaNiaC407
Looking for some advice on current issue with a 2012 150 Speedster 260hp
I recently changed out carbon ring due to water coming into bilge area while on a ride. I guess that I didn't put the seal in properly by the PTO and that is why I am leaking some oil. I also have the long beep followed by an Oil Pressure indicator which then goes off right away. I do not get a check engine light.
The question is that is the low oil pressure indicator something that frequently comes on when the seal is not properly installed? I just want to make sure that I don't have two problems here. (ie. Bad Sensor too)
