Oil injection???
s.yous
Hey guys
I'm not sure if my oil injection is working or not. The level of oil is still at 3/4 full and I filled the gas tank 3 times already. Is that normal? When I turn the engine on it does smoke as if it's burning oil and the engine hasn't seized so I'm assuming the oil injection is working.
What do you guys think?
Thanks
If you want to check it, when you start it grab the injector disc, and push it full open and see if it starts to smoke like crazy. It should as it pumps lots of oil into the engine. You could also mark the injector tank with a marker and see if the level drops any, when you run it.
Karl
Its probly past time (more than 2 years) to change the oil injection's two 3/32"id
x 6" long lines to RV spigots. (Weedeater fuel line). Bill
