super1c
Im sure my oil injection system is not working. Have run an entire tank of gas through and the oil tank has not gone down at all. Was running premix so engine was safe. I need to replace the 2 1/8" injector lines for sure, i found that the are leaking. They are original. Would this alone acount for not using any oil. Filter is new and pump has been aligned. This is a new to me ski and im learning a lot after the fact. Or would the injector nipples be plugged. If so how do i clean them. I did not clean oil tank before adding new because i didnt know better at the time. Ive searced and read a ton on this so far but just not quite sure. Thanks guys. 1995 GTX CCC
