cj3737 Active Member Sep 2, 2018 #1 97 717... Hopefully I'm not overlooking the obvious here... How do I disconnect the oil inject cable from the carb without changing the adjusment?
mikidymac Moderator Staff member Moderator Sep 2, 2018 #2 On that model you can’t. Pretty sure it uses the threaded adjuster and lock but on the throttle.
cj3737 Active Member Sep 2, 2018 #3 I was afraid of that.... guess I'll just take a pic before I loosen it and try to put it back the same way
mikidymac Moderator Staff member Moderator Sep 2, 2018 #4 No, just reset the oil pump arm to align the two marks. You should be doing this anyway whenever you mess with the carbs or idle.
