JTRICK8806
I have a 1995 XP. Before I bought it the original 720 motor had been replaced with a 587, and it has a Mikuni SBN carb on it. The ski seems to run fine at slow speeds but when you give it more gas it dies. I replaced fuel lines, cleaned the fuel filter, the compression is good, the spark plugs look good but are perhaps a little bit oily, and I cleaned the fuel selector valve. Still the same problem. So I opened the carb to make sure everything was clean and looking good. When I opened up the pump side I found quite a bit of oil in there. I'm not very experienced with two stroke engines, but I'm guessing that there shouldn't be oil in the fuel pump. I cleaned it out and put it back together, I haven't started it yet though.
Should there be oil there? Could this be the source of my problem? The ski is getting plenty of oil, as it makes a lot of smoke. I'm thinking I may need to adjust the oil flow. Any help will be greatly appreciated.
