TxAg15
Hey guys,
I have a 2005 gtx 4tec that was running just fine, until recently I had a coolant hose clamp going to the ride plate fail mid ride and lost all the coolant to the bilge. First indication was the overtemp beeper. Shut it off immediately and let it cool until I could make it to land. Replaced all the hose clamps, and refilled with antifreeze and thought it was good, until this last ride I found a dry dipstick and oil in the coolant reservoir and ride plate. So I just drained and pressure tested the coolant system to 13 psi and its leaking out the pressure over about 15 mins. I removed what oil was left in it through the drain plug in the scavenge oil pump and noticed some black specks coming through the suction tube.
Where should I start? Oil cooler? Water pump / Pto seal?
