[picture not viewable]
You should see the oil line from oil tank air bleed screw just above the highlighted
in red, pump alignment marks that you align with the cable adjustment nut at idle, that you can bleed air from the tank line. The two small lines have an oeteker clamp
to secure them to the brass nipple. You can squeeze them a little with needle nose
pliers to remove or install the new lines onto the nipple. Once on, you will need to
dribble a little injector oil into the carbs, then manually hold the pump lever to
where it would be if your throttle were at full position, then start ski motor and
hold the oil pump lever in full position until all air bubbles are out of RV lines. Clear
lines are best for veiwing the air bubbles out of the oil lines. Hope this Pic Helps!
