Now two seadoo's wont start!
surfski
These seadoo's (92 sp's) are really begining to irritate me! I just put in a new starter relay in the ski that wouldnt start. Got it all wired up pushed the ignition button and still nothing. I put a test light on relay terminal post's and it had power to the one coming from the battery and nothing to the one going to the starter. I then thought i would take the 5A fuses out of the running seadoo and try them, still nothing. So I put the fuses back into the seadoo that was running hit the ignition button and nothing happened. It was just working! What is going on? All I did was take out the fuses. The fuses are not blown and I even put new 5A fuses in and still nothing. What am I doing wrong? Now I have to seadoo's that wont start. PLEASE HELP! Its got to be something simple that I am missing
surfski
Did you ever figure out what caused the SP's not to start? I have a freind with the same issues. I also read your other posts, did you find out why there was water in the cylinders? Does it need a head gasket or possibly exhaust gaskets?
you might have a bad kill switch. Also you could have a bad wire going to the starter. Check those 2 things and reply back.
