Let me start by saying that I have read a lot on this site and have learned a punch. And sorry for the long post.
I recently picked up two skis for what I think was a good deal. One is a 92 SeaDoo XP and the other is a 94 SeaDoo SP. The SP will probably be parted out because it is in peices and I was told the XP “ran last summer”. Well after getting both I doubt the XP ran last summer.
I am mechanically inclined but I am completely new to the PWC/boat arena. I have only been on a jetski twice in my life. With that said I am troubleshooting issues on the XP and have a ton of questions.
It has a 587 white motor and I have read a bunch of different things on what the compression should be; anywhere from 100 – 160. I tested compression a few times and got 130 out of one cylinder and 120 out of the other. There was no fuel in the system so I did not have to remove old gas. I have verified that all the fuel lines are clear and I have replaced the battery, fresh gas, and plugs.
The problem I am having is lack of fuel delivery. At first I could not get the system to prime so I manually filled the lines and water/fuel separator with fuel. The ski will start but only run for about 4 seconds. With a little stater fluid it will run a little longer.
I am going to make or order a popoff tester so I can test the carb. I have checked the fuel selector switch and can get air through both the reserve and normal ports. It is important to note that all the fuel lines have been replaced at some point. They are not the grey SeaDoo OEM lines. Also, the oil system has been bypassed.
I have not pressure tested the fuel tank; how important is that?
I get pulse from the pulse line and can blow in a hose for the pulse line and hear the fuel pump click.
Should I focus more on the carb and a carb rebuild or fuel lines and tank? I did pull the remove the pulse inlet cover and the diaprhram looks ok but I have not properly tested the carb yet.
I should also mention that the ski has an aftermarket K&N filter with no flame arrestor.
Thanks in advance for the advice!
