Graigdooler
Ive owned this ski for 4 years now and has always been a good running machine. But this year i went to take it out and it did nothing when i hit the start button. The dash comes up and says 12v low. So i replaced the battery with a brand new AGM battery. Cleaned the terminals and coated them with anti corrosion coating. The 12v low message is now intermittent and has a over temp light on now. Checked the temp sensor and is ok. All wires are ok going to and from the mpem. Checked rear coil and fuses. All ok. I checked the switch next and found a broken wire. Replaced switch and fixed wires. Still nothing. It will crank over if i jump the start solenoid but other than that, it does nothing. Any ideas?
