I have a 1997 Sea Doo XP that is dead when the Stop Start Button is pressed nothing happens. I have a known good Battery and have Battery Voltage at the 5 amp fuse on the MPEM (which doesn't blow as it wont crank) Red Power wires have Battery Voltage however the Yellow and Red Stop Start Button Wire only has 11.8 volts Traced back to Connector 1 pin 22 if I remember correctly. It only has 11.8 volts coming out of the MPEM Pin has anyone got a known fix for this? I know about the Diode issue but that normally blows the fuse? Both sides of that fuse have Battery Voltage.
