I have a 2007 Sea Doo GTI SE 155. I've had Battery Voltage problems for about 10 months now so I've had old gas sitting in the ski. I have replaced the solenoid, spark plugs, ground wire, power wires to the fuse box, voltage regulator, and battery. When I put the key in and press start, it sounds like the engine tries to start but stops after one second and won't turn over. Is this most likely a bad fuel problem? I also noticed the wiring from the voltage regulator to the engine rear (I think AC generator) were burnt so I replaced those wires too.
I am planning to siphon out the old fuel, but what else should I do? I can't seem to find any Carburetor on parts lists online on my specific Jetski. Sounds like a dumb question but are there carbs on my ski? What else in the fuel system can I clean out?
