This trailer that came with the 97XP I bought was in dire need of new bearings, I could move the wheel up and down and side to side about an inch. Took it apart this morning, first time changing wheel bearings on one of these trailers, changed bearings in cars though. Anyways, when I got it apart there was no spindle washer and so far every video I’ve watched there was a spindle washer. How do I know if it was just forgotten last time or if it isn’t supposed to have one? By the way, there was no outer bearing, it just disintegrated, I found chucks of the old needle bearing in there and I’m guessing the piece I took out that was behind the castle but was the inner part of that bearing. Hopefully I can get a number off of the inner bearing otherwise do I just measure the spindle in order to know which bearings to get? I guess I could always take the other side apart and get the number me from that side.
This is all that there was before I took the hub off, should I put a spindle washer on, even though there wasn’t one there?
