NO SPARK to the PLUGS!!!
Nelmsjr
Well i got water into my rear electrical box.My Ignition coil fried and split open after i tried to start it.
Just replaced the coil and then engine turns over(starter is turning) But i took the plugs out and placed against the block and no spark at all.Power is getting to the two larger wires one on the left is always hot and the one on the right is lighting up when i crank it over with the light test..but the little white wire is getting no power when turning over(Light-Test). Somehow between the relay and the plugs..NO SPARK.With a brand new Ignition Coil.
Electricity sucks!!!
How many Black wires connect to the ignition coil ground(on the Bottom)I have 4 wires connected.Does any of those wires connect to the top of the coil..i noticed the top of the coil has a metal base plate also.
Thanks allot in advance.Im a SEADOO Virgin.
Is the small black wire connected to bat neg? Check the rear fuse and three
front fuses.
Conclusion to NO SPARK
i traced the wires yesterday and found that the electronic module assembly had melted in a spot where the purple wires go into the assembly and it caused charring and the epoxy to melt like goo. Now i would love to find a used Module for a 1996 SEADOO XP.
Thanks all for the help!!!!
