Mike Roberts
Hi, I am a new owner of a 1998 speedster, bought it from a friend, put about 25 hours on it so far, man let me tell you what a freaking blast, I don't think I will ever own a prop driven boat again , I love this boat. My problem is the right engine drive shaft stripped the splines at the engine,, the drive shaft part is stripped ,,, already took it apart , my question is should I replace the pto flywheel also . It feels fine but when I put the good side of the shaft in the pto flywheel ( the end that was connected to the impeller ) just to see how it feels. It has a little play in it when moving it slightly back and fourth,, and also how do I lock the motor in order to unscrew the pto flywheel from the crank ,,????
