Yes, I call it the CAN method. The later skis have the water outlet in the jet pump that accepts your garden hose. So quickly, ( longly) , I pinch off the drain line(s) , I remove the exit hose and attach a block off line, same 1/2 inch hose with a large bolt in it, etc. I remove the inline hose and connect my own 1/2 inch hose that is higher than the water bleed ( pisser) hose, I usually remove it. So, holding my in line hose, I fill it with straight anti freeze till the fluid comes out the highest point of the system, ( the pisser) . Therefore I have filled the CAN.
You can remove the small water injection hose at the water box,and pour some anti freeze in there, but, there is so much space in there, that it is not a freezing issue. Usually my very first move is to tip the ski up, start it, and blow outmost of the water in the box using the exhaust pressure and gravity. My very very first move is to add some stabil type product to the tank ( most threads will suggest you fill the tank to reduce condensation and water in the bottom) . My last move is to fog the motor through the removeable rubber nipple at the top of the air box, make sure your extension fitting is crazy glued so that it does not fall into the air box. Guess I should add the anti freeze into the water box after the fogging.
You can also change the oil in your pump as well. My very very very last move is to remove the battery, and bring it into my house and put a digital cheap pulse charger on it. You can of course, change the order of my moves, subtract from, them or add your own moves. I use straight anti freeze, not RV antifreeze. When you are done the anti freeze part, I remove the drain line pincher( s), and re attach the exit line hose. I have a large catch container under the pump to catch most of the draining anti freeze. Theoretically, you could leave the pincher and block off for the season, but the pinchers on the drain lines could squeeze, deform, and or crack them. I think by now you get the ideas and notions on my moves from decades of winterizing the early skis.
