New angle on engine, problem?
Tikkar
Hello! Im in the endgame in building my jetboat.
The engine in question is a 2007 951 DI
Just wanted to make sure BEFORE i started running it in water, that the engine angle doesnt affect exhaustcooling.
First time working on a jetski engine, and not sure if the exhaust is waterjackeded or if the water flows freely inside the pipe itself.
Since i had to mount the engine with less of an angle than it was in the 3D, i just want to make sure the coolingwater doesnt flow back in the combustionchamber as soon as i put it in the water.
Attaching pictures of the engine in the ski and in the boat.
As you. As you can se the fuelrail is completely vertical in the boat, and more angled in the ski.
Will it work? Thank you ✌
It could be possible that the water in the wet exhaust could flow back into the cylinders easier in this orientation. But as long as you don’t do something silly like having it on the hose with the engine off you will probably be ok.
Also if the final exhaust outlet is lower than the pipe and the pipe is above the waterline you shouldn’t have lake water flowing back into the pipe chamber.
Great to hear! Thanks
