will.capuano43
Does anyone have videos or manuals with removing the wiring harness its 2012 rotax-4 tech wake sea doo, i have removed it back to the engine but i can not remover the clips on the top what appear to be plugged into the ecu, this si my first time ever working on a jet ski, i have only worked on cars prior to this, so any help is greatly appreciated, i believe the intake blew up and the jet ski sunk which corroded the fuse box i have the back end from the battery to the engine disconnected and the front back to the engine so far, the clips are some i have never seen before and i don't want to try and force to remove them with out knowing the proper way to remove them. once again any help is greatly appreciated thank you,
