Would this be a 587 engine? Sent you a PM.I have a 93 GTS and Im looking to replace the carbs at a reasonable price. New to the PWC and need a little advice on where I should be looking for a fair deal.
Thanks!
The ones I have do have some corrosion on some of the inside surfaces. I could probably clean them up but I also noticed there is a small plate held by 2 tiny screws in each carb and the screw heads have been stripped...I have no idea what is behind those tiny plates and whether or not I can ignore them.You could always give Nick at West side power sports a call and see if they have any.
The real question is why replace them vs rebuilding the ones you already have?
You can usually get those screws out of there. Not sure if these are the ones that fit your ski. Came off a 587. You can probably fix yours.The ones I have do have some corrosion on some of the inside surfaces. I could probably clean them up but I also noticed there is a small plate held by 2 tiny screws in each carb and the screw heads have been stripped...I have no idea what is behind those tiny plates and whether or not I can ignore them.
where will I find replacement screws? is it a problem if I just leave them alone and not even go under those plates? I also see the needle seat screws are rounded but the seats look very clean so Im just gonna change the needles.You have to grind the ends off the screws for throttle and choke plates they are punched to prevent them from backing out
why change the carbs a replacement carb overhaul kit has all you need good clean down as you strip it I did my 1999 it’s great nowI have a 93 GTS and Im looking to replace the carbs at a reasonable price. New to the PWC and need a little advice on where I should be looking for a fair deal.
Thanks!
