need carb and fuel line picture
DDDDDD
i took my carbs of my 1996 GTX to clean them and replace old grey fuel lines and now i have forgotten how the fuel lines route to them (between carb). Can i get a picture of the carbs connected. There is also a section of fuel line with a spliter in it and i know it goes to the rear carb but i dont remember what it hooked up too and why there was a spliter.
thanks but i already looked there, i need to see the gas lines connected to the brass fittings in like a snapshot from the side of the carb where i can see it all connected together in operating order
Carbs......?
Start with the MAG carb. On the side plate, there is 3 hook ups. If you look at the carbs side, you'll see direction arrows. The mag carb center line is connected to the Pulse line going into the engine casing. The bottom line (verify with arrows) is the return line from your fuel pump. The upper line is fuel supply from the "Y" you are talking about. Then, the other part of the "Y" connects to the front side plate of the PTO carb and it has a bridge from the PTO carb to the MAG carb.
I have my airbox off. If you need me too, I can get a couple pix...:cheers:
yea if you could take a couple pics that would be great, ill get some pics of what i have later tonite
Pix......?
Are you still having a problem with your carb lines or did you get it figured out?
yea im still having the issue with the carb, but i have kinda put the seadoo on the back burner since my dad has been in the hospital and ive been spending time with him. I will mess with it this upcoming week hopefully.
