k_dog345 Member May 23, 2020 #1 I am rebuilding my carb, and can see obvious evidence that saltwater has compromised my mag carb. My Mylar check valve looks like this, is it ok?
k_dog345 Member May 23, 2020 #2 Also, any special suggestions on dealing with rebuilding a carb that had saltwater in it?
mikidymac Moderator Staff member Moderator May 23, 2020 #3 You have to replace the Mylar valve and it comes in the genuine Mikuni parts kits you are using. You are using them correct? If your carbs a damaged from salt corrosion there’s not much you can do. The aluminum is damaged.
k_dog345 Member May 23, 2020 #4 mikidymac said: You have to replace the Mylar valve and it comes in the genuine Mikuni parts kits you are using. You are using them correct? If your carbs a damaged from salt corrosion there’s not much you can do. The aluminum is damaged. Click to expand... Thanks man, yes I am. I found the small clear piece. I’m assuming the metal tab is on
