Multiple Fault Codes on 2020 GTI SE 170
CWOLAW
So, interesting day on the lake yesterday. New ski with only 10.3 hrs. Got through the breakin period!!
Issues started where it didn't seem to want to turn on at times and didn't seem to recognize the RF Key. Eventually it did and started up. Running around the lake, especially in hard turns, got error codes and red oil light came on and display said to stop the engine. Did that, wouldn't turn back on, but again, eventually did (Delay due to critical error thrown??).
Checked oil level, it's fine.
Connected to my CandooPro this morning and it looks like it threw a bunch of fault codes yesterday.
C2328(Validation Forward (Motor Not Powered within maximum delay);
P0568 (System voltage High);
P0562 (System voltage Low)
P0629 (Fuel Sensor Disconnected)
B2A20 (Connector A, Pin 4 Voltage out of normal Range)
P0461 (Fuel Sensor Input out of range, signal behavior abnormal)
B2A30 (Connector A, Pin 15 Voltage out of normal range)
B3E01 (Analog Input General Failure)
B2A40 (Connector A, Pin 5 Voltage out of normal range)
B2A21 (Connector A, Pin 4 Open Circuit or input of out of fault Range)
B2A50 (Connector A, Pin 16 voltage out of normal range)
So, based on all the above, I suspect I don't have a major problem, other than possibly a loose Connector A? Could that have caused all the faults? Can anyone point me to which harness connection is "Connector A"? At least, this seems to be a good place to start.
