My 2003 GTX 4 TEC had some water inside the engine and I made a mistake on trying to turn it ON without removing the spark plugs., I saw some water coming out from the exaust side then the engine quit turning. I removed the three spark plugs and I saw some water inside I used a portable water pump and I removed (water).
At this point I did not tried to turn the engine again because I do not want to damage it more if this is the case., I do not even know if it's going to turn without the spark plugs on it....
My next step is to put some W40 and leave there for 1 day and then try again and see if it truns.
1.- Do you think W40 will help?
2.- Do you think my engine is bad and it need to be open to fix it?
Thank you!
Botello
Thank you!
Botello
