motor mounts 1992 XP NEED HELP !
Crofoot50
Hey GUYS
I have a mint 1992 xp with 2 broken motor mounts on the carb side of the engine
I replaced the rear but the front bolt on the front mount is barely turning coming out :(
I worked it back and for which helps but it feels like its gonna snap in the hull.
any ideas ??? Do you think it would be ok to use it this weekend with one broken mount??
I am afraid its gonna snap off in the hull
that means I am pulling the motor which I can do but not before this weekend
Thanks for your help
Cro
I wouldn't use the ski with a broken mount. Increases the odds of impeller and wear ring damage.
Get a quality penetrate such as PB Blaster and spray the bolt, work it back and forth a bit and spray more, let it sit and soak,,,
