brandon32689
Well motor came in yesterday I got it back in and oil block off kit installed. Fresh lines going to rotary valve and out to give them oil. Cleaned everything and it fired up. Today I did the alignment and put a new wear ring was not that bad st all if anything my alignment is off a cm if that. Wear rung was easy cut old out n new slid in with a little force. No more gap like b4 I will get a pic tonight. I put jet pump back in with new seal and rtv around the inlets and new oring on cone. Filled to top with royal purple 75-140 and fired it up idles good and smooth. Will put vts system back in tomorrow along with making sure everything is tight. Also hydroturf will b here tomorrow.
