Monent of weakness Constant Double Beep
dosman99
I had a moment of weakness, last week I purchased a salvaged 2002 gtX 4TEC from a local internet auction site. ( I think I got a good deal LOL )I meet the owner when I picked up the sea-doo , he said it was washed off the lift and hit the shore and was bashed on the rocks. the engine compartment did not take on any water just cosmetic damage. I have experience with auto body so I'm not worried about the body, I can fix that. It was running in top order before the storm. Took it home and hooked up the hose and started no problem and sounded good. Also no warning indicated or maintenance lights.
pressed the button 5 time and no fault codes read.
So right now, just one simple question. plug in the key 2 beeps ( good ) then it just keeps beeping 2 beeps constant. From what i read the it indicating a faulty exhaust sensor of a fuel sensor.
Does this sound right? Any help is appreciated.
if the ski is not running and the key is on the post the ski will beep 2 times every few seconds to warn you that they key is on and you will kill the battery it is normal
Ha Thanks Kozer. I had that feeling that after I started it the beeping stopped. You can sure tell I'm a noob.
Reading the owners manual it doesn't say that or I read it wrong.
Thanks for the help
