lucky68 Member May 9, 2020 #1 I've been reading up and see that the mystik jt4 synthetic is a good alternative to the Sea-Doo synthetic. Just wondering if I can mix them.
mikidymac Moderator Staff member Moderator May 9, 2020 #2 Do. Anytime you switch oils you have to drain the system and replace the oil filter. Mystic is good oil.
mikidymac Moderator Staff member Moderator May 9, 2020 #4 Yes you do on the oil pump line and you better change it or the two different oils can gel and plug the filter starving the engine of oil.
AKnarrowback Well-Known Member May 10, 2020 #6 I stick with one oil on everything, sleds and watercraft. I have a line on a good synthetic for cheap and keep a couple gallons in the garage, that way I never come up short and have to substitue for a last minute ride. Don't mix your oils.
