Can anyone tell me what to torque the cover screws on a Mikuni BN-38 to? I have looked everywhere and can't find the torque, nothing in my service manual and qstorms guide says to torque to spec.
Also do I need to torque down the screws for the check valve housing? I had to use an impact driver to get them out so I'm assuming I should use it to tighten them back down?
Should I use blue loctite on all these screws?
Is it ok to replace the phillips head cover screws with bolts?
Is it ok to use a thread chaser on these to clean out the aluminum rust and old loctite?
Should I be using seadoo lube, sealant, oil, or nothing to apply the new o-rings and gaskets? Anything on the paper diaphrams?
What should I use to scrub off the old corrosion from my carbs? I tried carb cleaner and a toothbrush but no luck, didn't want to try anything else in fear of scratching the metal.
If I soak my carbs in a bucket of carb cleaner do I need to remove the choke and throttle shafts?
Sorry for all the newb questions, this is my first ever rebuild and I've searched all over these forums but can't find an answer (or a direct one) to any of these questions.
