man i hope this thing starts up
luckysaturn13
i have bad seadoo luck.....I do put in a good effort though I put in new fuel lines new oil and fuel filters drained the tanks put in new fluids new plugs new fuel selector switch new gel cell batteryand rebuilt the carbs and then it wouldnt spark... replacde cdi box n mepm... no spark... ordered a magneto coil and the other coil was un avabile took 3 weeks for the dealer to figure it out after they already charged me for it.... sent to jet ski solutions with my new coil and they rebuilt the other they also bead blasted the plate and repainted it and reassamble with a new wire harness for 120. its pretty sweet. i lost my bolts n wire holder strap. finally found bolts hour later found the strap .... stator was spo to be in today ups just rescheduled it for monday.... ive been working on this thing since the winter... i hope this thing starts up its starting to get discouraged.... damn my 94 xp
Just be certain there is lube in the cyls where the biggest friction is at and using premix in 5gallon loads until you are sure the OEM oiling is working - mark the tank and after you know it is dropping then just gas and go.
so it will be ok 2 run some pre mix and the reg then just go to the reg oil for the second tank after its verified that its throwing it in? how hard is it 2 change the lines from the oil pump to the cly? I shold have done it when i had my carbs off damnit! ugh. Have you ever changed yours out? the carbs have to be pulled to get in there dont they?
holy shit! I buttoned up the new stator today n it started! for the first time since i bought it. Im gonna take to the river tomorrow and see how it does! wish me luck hahaha
