Is the maint light on?
If no maint light then check compression and fuel pressure.
If you replaced the rectifier with aftermarket, start the ski on the trailer with a volt meter connected to the battery.
Read the voltage at about 4000 rpms. Voltage should be 13.5 to 14.5vdc.
Anything less or more is an indicator that the rectifier is bad.
