Hi,
So the past month and a half has been quite an adventure for me... first time working on a JetSki (2012 SeaDoo GTI 155 SE)
So heres the story:
After breaking down at sea and discovering the pump seals had given and the entire pump housing was corroded, I had no choice but to replace the entire pump.
I had a successful disassembly and after the new pump arrived, I installed it.
The new pump:
- Factory new
- Nose cone already on (pre-greased)
- New wear ring (NOTE: Impeller was harder to turn with the new pump in comparison to the old)
I installed all of the components, including the iBR successfully (with some struggle with the iBR being a pain).
Bare in mind I didn't use a torque wrench since I didn't have one available (will probably invest in one later) so all the bolts are in tightly.
After pulling the jetski out of the garage on a trailer to run with (with hose attached) it instantly started to squeal VERY loudly.
After I heard the noise I shut it off instantly but did try it maybe 2 more times but didn't continue and stopped before the motor has even finished turning.
I thought the problem could be the impeller being too tight on the wear ring (the impeller was recycled from the old pump but it is in immaculate condition).
Apart from that, everything functions correctly (iBR) and I was told by a friend who was observing from the back that the impeller was failing to turn (or at least struggling).
Thank you in advance for any advice, I'm scared to run it any longer (to possibly wear down the wear ring a bit (maybe?) for fear of damaging drive components).
tl;dr / summary:
New pump, old impeller, loud squealing noise from jet area, almost positive everything is installed correctly, didn't use torque wrench on bolts/nuts (could it be too tight?), please advise.
Max.
So heres the story:
The new pump:
- Factory new
tl;dr / summary:
Max.
