Midwest Dave
93 GTX has blue green oil in the tank so I am guessing it's TCW3 and should come out. Hopefully this hasn't damaged the cylinders. Also have a 95 GTS bought from the same guy and it has a yellow or golden colored oil in it that I'm guessing is mineral oil and okay for the model year.
Short of pulling the tank it looks like siphoning most of it and then removing the lower output hose is the way to drain? Might just drain them both just to be safe. There's no way to get it all out, is some residual oil going to gel with the correct oil. Finally, is full synthetic less likely to gel than mineral or should I go with mineral since it is the recommend type for the year and of course cheaper?
Any comments or advice would be appreciated.
