Location Of Water Hookup Port
I'm looking to purchase a 2003 Sea Doo Sportster 4 Tec 155 hp. I'd like to run the engine on land and need to know where the water hose hookup port is on the engine/boat. Once connected how long can I run the egine without doing an harm ?
connection is located on the left side of the pump mounting bracket on the back of the boat where the pump meets the transom.
You can run the boat about 2 mins on the hose. Biggest concern is overheating the carbon seal as it is usually cooled by the water the boat sits in.
Procedure:
Start motor
turn on hose
turn off hose
Stop motor
If you run the hose prior or after motors have been run could result in back filling the exhaust and possibly ingesting water into the motor. No Bueno.
