Tommy Shenanigans
PWC lists. My dealer says all these hulls tend to list left.
Thanks for your input. I have heard theories (from maintenance techs) about exhaust weight and weight of the water in the exhaust to battery location causing the list. Sounds reasonable until you consider the other 99.9% skis are level...and you're the only guy the neighbors ask if your new PWC just survived a U-boat attack. From what I've heard and gathered from the web, I think this has been happening for many years to nearly every make/model due to manufacturing defects (like the motor mount jig got misaligned). Hopefully SeaDoo admits this and you and I can get what we paid for. For anyone else, dealers are required to water test every PWC they sell, so I advise you to either get it in writing that it sits perfectly level, or better, insist that they put it in CALM water for you prior to purchase. Additionally, you can test out the motor, steering, jet alignment and how SKI mode works on your PWC...mine hiccups at first on every launch.I have a 2022 GTI SE 170 with exactly the same problem. Lists to port at rest. It doesn't affect performance although the machine tracks slightly to port with the steering dead centre. Dealer will look at it when it comes out of the water for storage in a week or so but they have seen the problem and don't have a known solution. Someone on Redditt said that the GTI hull is designed for the supercharged engine and the engine is centred with this in mind. The SE 170 isn't supercharged and, without the supercharger weight, there is an imbalance to port. I have no idea if this is correct or not but, if it is, it may apply to your SeaDoo model as well. I'll let you know what comes of this. Perhaps a counterweight in place of the bailing bucket in the front storage bin would resolve it but I would rather not add weight to the boat.
Thanks. I agree.I have a 2021 GTI SE 170, and have not noticed any leaning to one side and steering favoring one side over the other. But I know there have been a few posts over the past year or two of different skis leaning to one side - enough posts to make me think there is something to this phenomenon... as crazy as it sounds. I don’t know that anyone has posted what their final outcome was or repairs that were successful.
I've been curious about this as well. From how 2 of us had to lean right to level her, I'd say at least 50# considering the moment arm.I would be curious how much weight you have to put on the starboard rub rail to level the ski out?
What the guy from the boat house said is that all 170-155HP engines skis tilts a little too the left. The 300hp don't due to the turbo-charger that counter balance the weight to the right. All the skis there are like this. They have around 15 that tilts. Also the mechanic from the dealer said that is due to the water-box at the exhausting. Something funny is that to turn the ski if you tip it over is that on the stickers shows you to do that using the left as the axis - probably considering that the left side IS heavier than the right one.That's exactly how mine is.
