My 2002 Sea Doo GTX 4tec has some electrical gremlins. Unfortunately this was attempted to be fixed by a local shop when they replaced the MPEM, ECU and wiring harness (used). Unfortunately the next time I took it out the wear ring disintegrated and the ski sat through summer and into fall. Fast forward to winter. I replaced the wear ring/impeller and I go for a test run. Ski runs fine and then boom....everything shuts off. No beeps, nothing on the gauge, NADA.
I bring it home and start messing with it and it starts running again. Unfortunately I keep getting weird codes that will go away if I clean wiring connections enough/apply Deoxit. A second ago I had it working well enough with no codes but again it will randomly shut off. If I reach down to connector A on the MPEM and move it a little the ski will come back to life. Sometimes it comes back to life with no codes, some times it has codes. I can also turn the ski off if it's running by reaching down and moving that harness where it connects into the MPEM.
What do you guys think? I need to sell this ski but every time I think I'm close I need to drop another $300. I'm at the point where I've recently put in $1600 into this thing. I just don't know if I'm $200 away from a perfect running ski or $200 away from a ski that has one more random thing go wrong with it.
