Leaks - '98 Speedster (with pics)
slngsht
Just bought the boat last year, have about an hour of run time on it. When I pulled it out last, noticed a lot of water draining. So today, took it out to the local ramp, and just kept it on the trailer, started it and started looking for leaks... This is what I found:
The first pic shows two water leaks... the first one is at the tan colored hose on the port side. The second one is where a small stream of water was flowing from under the starboard motor in the channel with the arrow. Any idea where that might be coming from?
Also found an exhaust leak on the port side aft RAVE valve. Did a brief google and looks like there are rebuild kits for that. Suggestions on supporting vendors to order from?
Check your exhaust seals/boots on outside of hull. Mine were cracked and leaking water when loading unloading. Pain in the arse to change Part 56 in fiche.
