Key Compatibility/CandooPro Key programming
joaquin12345
Premium Member
Premium Member
I was wondering if anyone knew if I have a 2002 GTX 4 Tec and a 2004 GTI 2 stroke can I program them both on the same key? Also my question is if the key I have is already programmed to the 2002 gtx when I program to the GTI does it unprogram the key or its just programming to the MPEM. I just ordered a CandooPro If you were wondering how Im going to program the two.
The key is programmed to the MPEM so the key is essentially dumb and doesn't have a memory. So programming it to another ski will not remove it from a previous one.
I don't know if the 4tech uses a different key though.
The new 2017s i have have RFID chips i think... the spark base model has a generic one, the GTI SE 130 (and pretty much all of the others not a base Spark) have ones that are coded...
I can tell the difference looking at them because my Spark is all black by the clip but the others have the grey insert that i believe holds the RFID chip.
