just rebuild my mikuni carb and changed all the gas lines
Ron1994SPI
just did all the above on my 1994 seadoo spi and now it won't stay running any thoughts? and any ideas on whitch gas line shoud be where on the carb im confuessed? thanks
Download the manual for this ski...that will tell you where all the gas lines go...also in the manual should give you the proper needle settings for the carb needles,very important!!!Also make sure that the ski idls at about 2800 rpm out of water on flush line...GOOD LUCK!
easy.
Blow through line. The one you hear bubbles is the in and I think it goes on the bottom inlet on the carb. If you look at the plate with a mirror theres an arrow....
You'll have to suck gas back into line before connecting it back to carb though....
I just went through that on an older model. Had my fuel lines "backwards" or upside down or whatever. Like ocod said. Check the arrows on the carb to be sure.
thanks everyone i had the two backward and once it switched them it works great now :thumbsup: thanks agin for everyones help
