Hopefully you did not cook your engine by running it without oil.
Get yourself a small container, put it under the oil filter, disconnect it at the filter where it goes to the engine.
If oil flows out, maybe you are safe.
You will have to drain all the oil that is left in the engine.
Before doing that, find a source to purchase any brand of oil that is Low Ash API TC certified, then :1) bleed the oil lines; 2) fill your oil container it with oil.
Sometime back I posted a Thread entitled Rotax engine oils. Pull it up and find a brand that you can obtain in your area, or if you don't want to waste time just go to your local Sea Doo store and buy SD's brand, which likely will be twice as much as you can get it from other sources.
Remember, to either purchase the brand of oil that is listed on my list, or any other Low Ash API Certified oil that you can find that is not on my list.
Do not purchase any brand of TCW3 2-stroke marine oil.
