joe
j.hamilron
My 2000 rxdi sucked up a rope. I got it all cut out except for 1 piece that is around one of the impeller blades. I can;t reach in to get it out and I don't want to pull on it or I might bend the blade. What is easiest way to get at impeller, from the rear end or removing intake grill.
Consult your manual for the bolts retorque spec. Item #30 is the loctite. Loosening should be easy with your rachet socket set.
