Puddlejumper70
Hello everyone.
I am building a 11ft jet jon boat using an old abused 91 Seadoo sp.
The ski was junk but had plenty of potential to be resurected in a way that it will still have a long useful life ahead of it.
I have been lurking in the background for awhile searching and learning all that i need to make this project work out..i am at the final stages of assembly and starting to button up all the tiny pain in the ass details..lol..
I am now to the point that i need to explain my build so that i can get some questions answered
make,model of ski-------1991 Seadoo sp with a 587 yellow Rotax 2 stroke engine
boat------------------------------1981 Sears Gamefisher flat bottom fishing boat originally rated at 5hp outboard
these two toys have been melded together to make a nice little skinny water runabout..
I have done the oil pump elimination for the reason that the oil tank could not be mounted high enough to allow good gravity feed circulation,I have made a small oil loop in the engine compartment that holds 5oz synthetic 2stroke oil for the crank and rotary valve needs.that i will of course keep a close eye on too keep fresh and full.
My biggest question now is what TYPE OIL for premix fuel, and oil mix RATIO..this is going to be run in fresh water only,in mostly slow moving shallow rivers and large streams in the western/central PA areas.
I want to make sure i don't cook my engine that i have done so much work on to build this little fun machine.
Once again looking for proper type oil and mix ratios.
thank you in advance for any advice.
here are some pics.
here are some pics.
