mattydipps New Member May 8, 2013 #2 I think all 4 tec motors use the same motor mounts in the same location.. If you do change the motor to a different size make sure you get that ecu for the different motor
K Killertiller New Member May 8, 2013 #3 I would never ever bother unless it was direct bolt in and go.
KK40384 Premium Member Premium Member May 8, 2013 #4 They do bolt in but th supercharged motors have lower compression so if you plan on using just the short block you will lose some HP if you don't supercharge it.
