My 08 Challenger 180 was running fine then just shut off. It Cranked back up then shut off again a few minutes later. Did this several times, then nothing. The dash went blank and it wouldn't start but the horn and blower still worked. If you let it sit, eventually it chirped and you could start it back up. If you turn the power switch off and back on, the dash would blink but then go blank. I changed keys, checked fuses wires and connections, everything looks fine. There was a relay on the small fuse box in the back that was really hot. Any ideas?
