Impeller Question
JoeMc
Here is a picture of the impeller the guy who was repairing my wear ring replaced took. Does this impeller need changing? I am new to PWC. Would appreciate it if anyone can help. E9B1B498-0933-4F0E-9ECE-C7702FCBB373.jpeg
Nicks don't help, they can add to cavitation. You don't say what motor, but the higher the HP the more critical for a smooth edge. Some carefull filing will clean that up. What's more critical is the end that almost rubs the wear ring. With a new wear ring it should literally just clear if not slightly rub on the ring. If it's worn so there's a gap of even a 32nd of an inch it will cavitate on higher HP motors. Can't tell the ring to impeller clearance in a picture.
It looks like that impeller has seen some machine work; I see a lot of tool marks & the edge at the 9 o'clock position has a lot of distortion, but it's hard to zoom in and keep the detail of the image. I'd get rid of it. Are you riding the 130 HP 2-stroke?
