RG123
Hi everyone, I have a quick question for you. Because my wear ring was damaged (big gouge in it) and there was a medium sized gap between it and the impeller, I replaced the wear ring with an OEM ring. It seemed to seat in to the pump housing well, and didn’t require much force to slide it in (was frozen first). Pump shaft, bearings all seem to be in good shape. Installed impeller carefully, making sure the washer was seated correctly and the seals weren’t pinched. After install, I noticed the impeller doesn’t seem to line up perfectly inside, such that the leading edge of 2 blades rub the wear ring, where there is a gap along the rest of the blade. See pics. I can still turn the blades by hand when installed with some effort, but it’s enough to prevent the engine from turning over when it was installed. Do I need a new prop? Should I just try to run it as it is, or did I mess something up with the install?
Thanks in advance!
Thanks in advance!
