I have a 97 gtx limited that i just got running thanks to SEADOO forums. Its idling way to high (4000-4500 rpm). If you hit the throttle it bogs. I cleaned the carbs but broke the T fitting. Took that carb back apart and drilled and replaced with a brass nipple and a brass T. The gas in the ski has been in it a couple years so i mixed a couple gallons of 40:1 with it. Any thoughts?????????
